1992 Chevy Silverado coursity lights
20,000 MILES • V8 • 2WD • AUTOMATIC
DAVPUDD
lights off,door open,have to jump 20 amp fuse from lighter to work, will not sut off until jump disconnect, need location door button switch both sides
Feb 25, 2010 at 2:50 AM
JDL
  • 16,098 POSTS
hi, your talking about the interior lites that come on, when you open the door? How come the fuse circuit has no voltage? As far as the switch, look at the door frame, inside where the hinges are, is there a plunger that goes in and out when you open and close the door, that's it. Your going about that the wrong way, don't get mad, just trying to help. Goodluck
Feb 25, 2010 at 3:28 AM
