1992 Chevy Silverado Brake Problems
115,200 MILES • 6 CYL • 2WD • AUTOMATIC
TCAMP55
Bleed entire system. Pedal will feel hard, start vehicle up. Pedal goes to the floor. Have replaced two front calipers/flex hoses/master cylinder. Please help me find what I am missing. The systems is disc front/drums rear vacumn boost system
Mar 7, 2010 at 3:15 AM
BLACKOP555
  • 10,386 POSTS
is abs module bled? metering valve? did you bleed it in proper sequence? any fluids leaking? when did this first occur
Mar 7, 2010 at 7:40 AM
