1991 Chevy Silverado Won't stsrt
DRTRACER37
  • 1991 CHEVROLET SILVERADO
  • V8
  • 14,100 MILES
Truck wouldn't start one day, rolled over & if I put fuel in carb, it would burn that & stop. I tapped fuel tank w/ rubber mallot and it fired right up. Was ok for 2 weeks until I had to pull the trusty mallot from behind the seat, started right up again but later that day, I had to leave it parked over night at a store. Next day, I replaced fuel pump in tank and thought I
had it fixed until 4 days later, won't start again. I pulled off the filter in front of the tank, and when the key is turned on, gas pours out. I replaced the filter with a new one. Still won't start. I pulled fuel line from carb and rolled engine, Shouldn't fuel be coming out of line? I got nothing.
Sunday, May 18th, 2008 AT 7:53 PM
PEAR69
  • 1,482 POSTS
Yes, Your engine has a Throttle Body (TB) not a carburator. There are two fuel lines going to the TB, a feed line and a return line. Make sure you are checking the feed line -- this will the bigger one that comes from your fuel filter.
Being that you tap the tank and the engine starts tells me that the problem may be the fuel pumps ground. A commonly overlooked problem.
Monday, May 19th, 2008 AT 5:45 AM
