1991 Chevy Silverado shift linkage problem
SHAWN092080
Transmission problem
1991 Chevy Silverado V8 Four Wheel Drive Automatic
i have a 91 chevy k1500 and was plowing snow with it after going forward and then backing up my truck would not go down into drive only park and reverse now in still only can move the shifter in those two positions but the truck won't turn over eighther what could be the most likely problem
Feb 19, 2010 at 10:43 AM
2CARPRO JACK
  • 11,533 POSTS
Could be either thecolumn or the trans.Shut truck off, set e-brake and chock wheels.Disconnect shifter at trans and see if the trans will move through the gears, if so try column.This will at least tell you which one it is.Could be broken Neutral switch on the bottom of the column making it stop.
Feb 20, 2010 at 1:13 AM
