1991 Chevy Silverado fuel system
212,000 MILES • V8 • 4WD • MANUAL
MCZECH74
My truck idles fine, but when I try to move it, it will die out right away when I release the clutch. I have replaced the egr valve, fuel pump, fuel filter, spark plugs and wires. I am wondering if this could be something to do with the fuel pressure regulator, or even the operation of the clutch, which was replaced 5,000 miles ago, along with a new slave cylinder and master clutch cylinder.
Oct 24, 2009 at 8:28 AM
  • 75,988 POSTS
Check the fuel pressure, and test the throttle position sensor and manifold absolute pressure sensor.
Oct 24, 2009 at 9:03 AM
