1990 Chevy Silverado runs hot
VMCGHEE68
Engine Cooling problem
1990 Chevy Silverado Two Wheel Drive Automatic
put new radiator new heater core and it still is getting hot .how do i check my water pump?
Mar 14, 2009 at 5:20 AM
BLACKOP555
  • 10,386 POSTS
quickest way is when engine is hot after thermostat is opend is to pinch upper hose shut, then release, you should feel pressure build when pinching it, and when releasing you shoudl feel the water rush by
you can also pull a hose and see if coolant flows out of it, watch out for it beign hot.
Mar 14, 2009 at 4:18 PM
