I am having a problem with my truck when i first go through the gears. It seems like it is missing unitill i go through the gears the first few times. Once i go through about three or four times it seems to even itself out and run fine. I have already changed the plugs, wires, cap, rotor, fuel filter, and also the air filter. I thought it might just be some bad gas or possibly the injectors so i have put some injector cleaner in the fuel tank but i still have had no relief. not sure what the problem is. I was wondering about the timing but i figured it would be doing it all the time if it was the tming. Also do you think it could be the fuel pump?
Sep 22, 2008 at 2:04 AM
