Front differential not engaging?
DC379
Drive Train Axles Bearings problem
1990 Chevy Silverado V8 Four Wheel Drive Automatic
I have seen 10,000 post for actuators and not a single bit of useful knowlage if the actuator is not the problem. Is there anyone out there with this information? The tranfer case is good! The actuator is good! Still the front axles do not engage. Thow me a bone here and let me in on the secret I'm dying here!
Dec 12, 2009 at 7:28 AM
1990CHANCE
hey i had the exact same thing. go on top of your transfer case there is two switches one on the side one on the very top unplug the very top one and take a 7/8 or 22mm socket and were that switch plugged in, take the metal piece out of the transfer case with the socket and get a new one. than thread it back in and plug the switch back in and it shoukd work. i worked on mine for 6 months beofer i figured it out. hope it works for ya
Dec 20, 2009 at 10:13 AM
DC379
I have the same problem, but the problem is in the front differential. The actuator is working but whatever it pushes against is broken.
Jan 14, 2023 at 9:17 AM
  • 55,649 POSTS
The shift fork sounds like it is broken, check out the images below. Check out the images (below). Please let us know what happens.
Jan 14, 2023 at 9:18 AM
