1990 Chevy Silverado 1990 Silverado Coolant in oil
164,000 MILES • V8 • 2WD • AUTOMATIC
DABARTON
Recently overheated, now the crankcase has coolant in it, could this be from a blown head gasket or cracked block. If so how can i determine if it is a cracked block. Would maybe replacing the intake manifold and gasket fix it if it's not the block.
Oct 18, 2008 at 5:38 AM
  • 75,988 POSTS
Could be the headgasket/ or cracked head or block to determine where-get it block and pressure tested.
Oct 18, 2008 at 5:43 AM
