1989 Chevy Silverado Tail lights
CASHDAWG644
  • 1989 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 180,000 MILES
I recently replaced a turn signal bulb on the passengerside tail lights. The lights worked for about 2 weeks then the turn signal and brake light stopped working. When you turn the park lights on the bulbs light.
Tuesday, October 13th, 2009 AT 4:25 PM
Check and test the flasher unit and the turn/hazard switch.
Tuesday, October 13th, 2009 AT 4:52 PM
CASHDAWG644
Wouldn't a faulty flasher affect both sides?
Tuesday, October 13th, 2009 AT 4:54 PM
Won't hurt to check it I strongly recommend you test the DIR/HAZ switch and check for an open circuit between the switch and the bulb socket which is the dark green wire.
Tuesday, October 13th, 2009 AT 5:03 PM
