1989 Chevy Silverado Oil Pan
200,000 MILES • V8 • 4WD • AUTOMATIC
STRETCHINOUT
My 1989 Chevy Pickup oil pan has rusted out and is leaking. Is replacing the oil pan my only option?
Is there a sealer avaible that would seal up the small pin holes in the oil pan?
Thanks!
Oct 1, 2008 at 1:04 AM
2CARPRO JACK
  • 11,533 POSTS
You will need to replace the pan. It will come right out of the truck if you remove the inspection cover off the trans. I suggest an OE pan, the cheap aftermarket ones tend to leak
Oct 1, 2008 at 1:11 AM
