WE HAD REPAIRS DONE SEALS AND GASKETS FLUID PAN GASKET REPLACE OIL PUMP SEAL REAR MAIN AND REPLACED INTAKE MANIFOLD AND I WAS TOLD AFTER THE REPAIRS IT WAS LEAKING FROM THE TOP SO I CHANGE THE VALVE COVER GASKET ON BOTH SIDE AND STILL HAVE A LEAK AND MY TRUCK STILL SMOKE UNDER THE HOOD ON THE PASSAGER SIDE.
SPONSORED LINKS
Sunday, May 3rd, 2009 AT 8:32 PM
MECHANIC
If I had to guess, I would say there is a problem with the valve cover on that side, cracked, warped. For you to see smoke, most likely it is coming off the valve cover on to the exhaust manifold.
