I have a problem with wiring diagram, fuseable link wire( grey )going to ecm is bad . But it is on post cloest to driver side.
Oct 30, 2009 at 8:46 AM
JDL
✓Experienced Mechanic
Welcome, not sure I understand your post? One of the wires off positive battery post, should go to junction block, just follow the wire. The fusible links are at the junction block. You can take negative battery loose, so the junction block is dead.
Oct 30, 2009 at 9:15 AM
609LEN
MEMBER
Im sorry , Im talking about fuseable links; posts on juncton box do not match wireing diagram ? Wires have not been moved.Facing juntion box 1st post on right, grey to fuse to red to ecm ?
Oct 31, 2009 at 2:00 AM
JDL
If I don't know which fusible link is which, I test them all. Just get past the link, use a testlite start checking.
If you want to know which circuit it is, take the suspect circuit loose at both ends, make sure there is no voltage, do a resistance test. See if there is continuity between the ends.
