1989 Chevy Silverado electrical problems
210,000 MILES • V8 • 2WD • AUTOMATIC
TEDALLEN26
i have a 89 chey 1/2 ton p/u ive replaced the fuse and the fuel pump relay. it will run for a couple minutes and die and blow the fuse . i replace the fuse and it will start and run for about 10 minutes and die and blow fuse again what could be the promblem.
Aug 29, 2008 at 3:10 AM
RHALL77
  • 3,361 POSTS
sounds like a possible fuel pump shorting out or a wire is shorting to ground
Aug 29, 2008 at 5:37 AM
