i am installing an intake kit in my chevy pickup. the kit came with a small hose that should connect the back of the intake to the valve cover breather tube. the problem is i cannot find this tube. there is only a small air filter on the valve cover. would it be ok to install the intake without connecting that hose? or is it possible to remove that air filter and buy a breather tube to replace it so i can connect the hose to the back of the intake? i would like to avoid any damage to my pickup so this project is on hold for now. any help you will be appreciated. thank you.
Mar 8, 2008 at 5:24 AM
