1989 Chevy Silverado 89' Chevy not getting enough fuel.
89Z71
  • 1989 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 204,000 MILES
My truck is getting gas but not enough. My first step was to replace the fuel filter but that did not work. I am getting gas to the carburator which is weird. It has the overhead injectors, I rebuilt the the fuel pressure regulator (diaphram, new spring, etc.) & Cleaned everything except the inside of the injectores, ( I doubt that both injectors clogged simuainisly ) but I guess anything is possible.
I do have gas comming out of the injectors, but not enough. The truck will not start unless I pour gas or starting fluid in, then its starts up just fine, but as soon as it burns out th truck shuts off, but you can still watch gas come out of the injectors.
I personally haven't ever seen a problem like this, so I'm stumped now.
Thanks for the ideas.
Thursday, March 27th, 2008 AT 9:19 AM
Do an actual fuel pressure check with a fuel pressure tester and comeback with the readings-EFI system are very picky on fuel pressure-check it
Thursday, March 27th, 2008 AT 9:24 AM
89Z71
Yep, it was the pump going out, only 20 lbs. Of pressure. I changed out the pump & its just like new. I always thought when a pump quit working that it just stopped all together.
Live and learn I guess. Thanks for the help.
Friday, March 28th, 2008 AT 5:59 AM
Your welcome and good luck! Tell friends about us were here to help people with car problems-
Friday, March 28th, 2008 AT 12:09 PM
