1988 Chevy Silverado what do i do now?
126,619 MILES • V8 • 2WD • AUTOMATIC
HOGDADDY71
i have replaced wires,plugs,distribtor cap & rotor,fuel filter, cleaned injectors, and it still lopes,and almost dies, any ideas?
May 21, 2010 at 2:20 AM
  • 75,988 POSTS
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
May 22, 2010 at 6:48 PM
