1988 Chevy Silverado Speedometer and Odometer Not Working
KNAHLI
Transmission problem
1988 Chevy Silverado V8 Front Wheel Drive Automatic N/A miles
About a year ago my odometer stopped working after I had the oil changed at a dealership, I've recently had both the motor and the transmission replaced and now the speedometer isn't working. What could be causing the problem???
Apr 1, 2008 at 11:05 AM
MASTERTECHTIM
  • 4,750 POSTS
if the odometer stopped working and the speedo was still working then you need to replace the dash cluster or the speedo head. also check the vehicle speed sensor located on the transmission for the speedo problem
Apr 1, 2008 at 11:13 AM
