I have 1988 chevy silverado 305 half ton 2 wheel drive automatic. It idles fine but misses badly under power. I have replaced the egr valve, egr pressure switch, fuel injectors, the diaphram in the carb, distribitor cap and rotor button, checked timing, it is correct so timing chain is ok. The coil is functioning fine and i have spark to all cylinders
Sep 30, 2009 at 2:14 AM
