1988 Chevy Silverado differental
125,000 MILES • V8 • 4WD • AUTOMATIC
MOSS965
when i put in gear (not all the time) it chucks and slips then if i step on it or stop and back up a little it straightens up for a while now its is doing more often almost like it slipping,...... thank you , cliff
Dec 19, 2009 at 3:19 AM
  • 31,937 POSTS
Hi there, thank you for the donation,
I would first be checking that the correct oil is in the diff. failing that if this is a limited slip diff, the clutch pack may be failing causing this problem, have it check out before you do more damage.
mark (mhpautos)
Dec 19, 2009 at 2:34 PM
