My parking brake light will not go out, what could be the problem?
Monday, February 25th, 2008 AT 9:41 PM
BLACKOP555
MECHANIC
The brakes may be sticking in the rear which happens quite often. Or the shift linkage is all rusted and should be greased up and worked with. If that doesnt help then the switch is probably bad.
SPONSORED LINKS
Friday, March 14th, 2008 AT 4:53 PM
BLACKOP555
MECHANIC
Did I mention it may mean you have low brake fluid also!
