1987 Chevy Silverado no fuel
116,000 MILES • V8 • 2WD • AUTOMATIC
MILTECH
Will not start when engine is hot. No fuel. Replaced bad starter.
Jun 19, 2008 at 5:14 AM
RHALL77
  • 3,361 POSTS
is it fuel injected? if it is do you have voltage at the fuel pump.
Sep 3, 2020 at 3:07 AM
MILTECH
yes fuel injected, how do i check for voltage at fuel pump
RHALL77
  • 3,361 POSTS
you will need to take a test light and check the terminals at the fuel pump in the tank. the test light should come on for a few seconds everytime the key is turned on.
MILTECH
fuel pump o.k. what else should i check
RHALL77
  • 3,361 POSTS
can you hear your fuel pump make noise when the key is on. another thing to check is see if you have injector pulse at the injectors
MILTECH
I can hear the fuel pump come on when I turn the key. But when the motor has been running for awhile the temp. is at normal operating condition, and I turn the key to see if the pump comes on, it only comes on sometimes and finally it does operate at all and the motor will not start only turn over and there is no full. Is this a faulty fuel pump? Or somehting else.
RHALL77
  • 3,361 POSTS
sounds like you are on the right track. if the pump is not turning on and you have voltage to the wire, i would say you have a fuel pump issue and should replace it.
