1987 Chevy Silverado Coolant Leaking in Passenger Floorboar
350,000 MILES • 6 CYL • 2WD • AUTOMATIC
JD329
  • 16 POSTS
After driving the truck about ten minutes coolant started leaking in the passenger's floorboard. What is causing this?
May 12, 2008 at 6:01 AM
THE FACTORY MAN
  • 50 POSTS
You have a coolant leak in the heater core or the heater hose connection going to it. Usually the heater hose connection is seen as an external leak.
May 13, 2008 at 4:59 AM
