HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Silverado
Ignition
Distributor
1986 Chevy Silverado vaccum advance distributor
PANDA1126
MEMBER
1986 CHEVROLET SILVERADO
Engine Mechanical problem
1986 Chevy Silverado V8 Two Wheel Drive Automatic
what vaccum line goes to the distributor
Saturday, January 16th, 2010 AT 5:41 PM
MECHANIC
Is this a Carb or an EFI fuel system?
If its a carb the vac advance operates on ported vacuum meaning it takes its vacuum above the throttle plate
On EFI no info available
Saturday, January 16th, 2010 AT 5:47 PM
Please
login
or
register
to post a reply.
Related Ignition Distributor Content
Shorted Wires To Distributor
My Truck Has Had A Shorted Wire Going To The Distributor For Years, Pinched Between The Engine Block And Transmission, Just Found That Out...
Asked by
Johnny Cardin
8 IMAGES
1998
CHEVROLET SILVERADO
VIDEO
Distributor Replacement
Instructional repair video
GUIDE
Ignition Distributor Installation
An automobile engine ignition distributor is used to allocate the ignition spark from the coil to the appropriate cylinder for the combustion process to occur. In this guide...
1979 Chevy Silverado Hei Distributor
A Friend Of Mine Has Taken The Distributor Out And Then Cranked The Engine Over, What Is The Procedure To Get The Distributor Back In For...
Asked by
HORMONE
1 ANSWER
1979
CHEVROLET SILVERADO
Misses Real Bad In High Gear I Changed Dist. Cap...
Misses Real Bad In High Gear I Changed Dist. Cap Plugwires And Plugs Still Misses You Can Pull Any Plug Wire Off At Idle And It Dont Change...
Asked by
chevytruck92
1992
CHEVROLET SILVERADO
1993 Chevy Silverado 1993 Chevy Silverado
I Have A 93 Silverado That Runs But Dies. I Was Told That It Was My Distributor But It Wasn't By A Mechanic. I Thought It Might Be My...
Asked by
kwallace2122
1993
CHEVROLET SILVERADO
Timing Seems Off. Lots Off Spark Knock Using 87 Octane...
Timing Seems Off. Lots Off Spark Knock Using 87 Octane. Turned Distributor Once Before And Seemed To Help. Can't Remember Which Way To Turn...
Asked by
Anonymous
1 ANSWER
1991
CHEVROLET SILVERADO
VIEW MORE
How to Repair an Engine Cylinder Misfire
Spark Plug Replacement Honda
