CAN I RUN A 180,OR 160 THERMOSTAT.OR IS THE 195 THE BEST TO RUN
Jun 11, 2010 at 3:30 AM
✓Experienced Mechanic
You should use the recommended temp range for you engine, it looks as if it should be the 195, if you have over heating issues still, check for a blocked radiator, faulty pressure cap, external leaks and sufficient air draw from the cooling fan.
