1986 Chevy Silverado
POPSSMITH
An auto repairman has tried to fix my truck. Two days after I drive it home all of the transmission fluid runs out on the driveway again. I think it is called a D tent (?) cable that goes from the carburetor to the transmission. He replaces the little part that looks like a top hat with a hole in the top and gasket where it goes into the transmission. It isn't even being driven and the fluid runs out again, for the third time. What can be causing this to happen? Regretfully, I have decided to sell "Ole Blue" after all these years, but I need to get it fixed first. Any ideas would be greatly appreciated.
May 27, 2008 at 8:41 AM
MASTERTECHTIM
  • 4,750 POSTS
if the seal has been replaced properly and it is still leaking then the cable must be cracked or the transmission housing is cracked. look real close at the cable housing. let us know
May 27, 2008 at 9:15 AM
POPSSMITH
Thanks for your quick response. Will let you know as soon as we get it checked.
Thanks again
May 27, 2008 at 11:27 AM
