1981 Chevy Silverado head lights blink on and off
101,589 MILES • V8 • 4WD • AUTOMATIC
BULLWHIP1
hello
i have a 4 headlight system 1981 chevy 1/2 ton 4x4 , the head lights will start blinking after being on for about 1/2 hr, it only does this when they are on bright, and then both dim and brite blink, if i leave them on dim, they will stay on, with no blinking,
it does not matter if the truck is moving or setting still, they still blink
i have replaced the headlight switch and the dimmer switch 3 times, thinking i might have gotten faulty ones, this is about to drive me crazy !
also replaced all bulbs and sockets, and none of the other lights are affected !! like, dash, brake, turn signal.they dont blink
i am think of getting a heay duty headlight harness from LMC, that draws power from the battery, instead of the headlight switch. !!
can you help with this problem ??
thanks
charles
Oct 20, 2009 at 8:25 AM
PEAR69
  • 1,482 POSTS
Does it do this when the engine is running? Do the lights go completely out? Did you check the ground connection?
Oct 20, 2009 at 1:55 PM
BULLWHIP1
yes it does it when the engine is running, and it does it with the engine off , and yes we check and cleaned all the grounds
Oct 20, 2009 at 2:52 PM
PEAR69
  • 1,482 POSTS
Do a voltage test drop test on the circuit. It sounds like you have a corroded wire somewhere. Test the voltage drop on both the negitive and positive side of the circuit.
A wire may appear to be good, it may even have continuity, but below the insulation - it can be corroded or broken. Causing a voltage delivery or drain issue.
Check the harness connector (the electrical plug). Make sure the internal connecting tabs are making good contact.
Oct 20, 2009 at 3:14 PM
