hello
i have a 4 headlight system 1981 chevy 1/2 ton 4x4 , the head lights will start blinking after being on for about 1/2 hr, it only does this when they are on bright, and then both dim and brite blink, if i leave them on dim, they will stay on, with no blinking,
it does not matter if the truck is moving or setting still, they still blink
i have replaced the headlight switch and the dimmer switch 3 times, thinking i might have gotten faulty ones, this is about to drive me crazy !
also replaced all bulbs and sockets, and none of the other lights are affected !! like, dash, brake, turn signal.they dont blink
i am think of getting a heay duty headlight harness from LMC, that draws power from the battery, instead of the headlight switch. !!
can you help with this problem ??
thanks
charles
thanks
charles
Oct 20, 2009 at 3:25 PM
