1977 Chevy Silverado Rough Start and Loss of Power on accel
150,000 MILES • V8 • 4WD • AUTOMATIC
TOMMYGUNN02
I have a '77 chevy 3/4 ton with a '95 5.7 350 in it, when i start the truck it takes a few really hard cranks before it catches, it sounds very similar as if i had a massive cam in it. then it catches and runs strong. the other problem comes in when i accelerate hard the engine boggs and almost chokes itself out. so i cant climb hills and when i try im almost stopped by the top because i cant accelerate hard. I replaced the fuel filter, the pump sounds good and engages as it always has. i checked the spark plugs, they looked good. the cap rotor and distributor assembly all look good. just cleaned out the TBI and put in new gaskets. i have no idea where to go from here so any advice is greatly appreciated.
Feb 24, 2010 at 12:15 PM
  • 75,988 POSTS
Hesitation,lack of acceleration,bogging,chugging etc.
Inspect and test all the following listed below:
Oxygen sensors.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Feb 25, 2010 at 8:00 PM
