Voltage Drain
CHEVROLET S-10
MUDDSHARK1308
I have a 1989 S-10 with 4.3 V6, Automatic and Tahoe package. It has a slow battery drain. We disconnected the main feed to fuse box on the firewall and it stopped the drain. Could it be in the ignition in the column?
I have several people that think it may be the problem. How do i remove ignition?
Aug 17, 2007 at 12:09 PM
SERVICE WRITER
  • 9,123 POSTS
Re-connect main feed and check draw on each circuit by removing one fuse at a time until draw is around 30 milliamp or so (normal). Then you will know what circuit it's on.
Aug 17, 2007 at 12:24 PM
[quote:21059837c2="Muddshark1308"]I have a 1989 S-10 with 4.3 V6, Automatic and Tahoe package. It has a slow battery drain. We disconnected the main feed to fuse box on the firewall and it stopped the drain. Could it be in the ignition in the column?
I have several people that think it may be the problem. How do i remove ignition?[/quote:21059837c2]
What you just did was disconnect the source of the short circuit-
Case Drainage:
Do this with the voltmeter put neg. lead to neg. terminal of battery. Now probe the top of the battery with the positive lead any readings other than .002 you have a case drainage. clean up with baking soda and water
Parasitic Drain 30milliamps down and better.
You need to follow Mr. SW advise-Hence in the event you remove all the fuses and drainage is still there-disconnect the alternator if that kills the drain you have found your bad friend in the alternator called Diodes- If not keep going we're watching you
You sure the battery is not sulfated. To check do the 3-minute test, apply a 35amp charge to the battery within 3-minutes if battery voltage goes beyond 15.5 volts bingo the battery is sulfated.
Good Luck
Aug 17, 2007 at 5:22 PM
