transmission
JESSEMDAILEY
I would like to know what size hex the transmission drain plug is and how much fluid to add for my 1999 cheverolet s10 manual V-6?
Apr 19, 2007 at 11:34 AM
TRUEFIRE04
  • 35 POSTS
on mine there was no drain plug...had to drop the hole pane, to change the filter....if you change the filter your going to need bout 5 quarts of trany fluid.
May 2, 2007 at 6:32 AM
