Service engine soon lights
ZZ7M8R
  • CHEVROLET S-10
I have a 1999 s10 2.2L with 51000 chevy.
The last time I drove it the service engine soon lite was flashing and it was miss-fireing. II stopped for about 2 hours when I started up again the service engine soon lite was on solid. The gas cap is secure. Could a clogged fuel filter be causing this or should I have it checked out by a machanic?
Thanks
Sunday, July 15th, 2007 AT 12:34 PM
LEB
  • 45 POSTS
The light reports hundreds of codes, that can be for any of the systems in the truck.
If you are a DIYouselfer, look for a SAM unit around your neighborhood. We have one down the street at the kwik Kar place. For $15 this will measure and report everything.
Most mechanics won't give you all if the codes and diag. Because that's not what the do. They fix things that break.
Sunday, July 15th, 2007 AT 5:23 PM
