S-10 turn signals
JIMBO56
96 S-10, 80,000 miles. None of the turn signals flash, but all of the bulbs will light. Also, pushing the emergency flasher button on the steering column does nothing. Is there a flasher module somewhere that needs changed?
Thanks.
Jul 5, 2006 at 12:05 PM
MIKEYBDMAN
  • 623 POSTS
Below the radio, screwed to the bottom of the lower edge of the panel below your cig lighter is a Power Distribution Center (Hazard Lamp Flasher, Seat Belts and Ignition Key and Lamps alarm, Turn Signal Lamp Flasher) Unit. I would start there.
Jul 7, 2006 at 12:43 PM
JIMBO56
Thanks for the reply, I'm sure it's the flasher, but the owner's manual doesn't show the power distribution center you spoke of, so I didn't know where to look.
Jul 8, 2006 at 6:45 AM
MIKEYBDMAN
  • 623 POSTS
The owners manual is not going to go into too much detail on the maintenance of a vehicle.
I would start by getting in the floor and looking up behind your cigerette lighter and see if you see a small panel with wires going to it, and several little square plug-in units attached.
It may be best to go to Advanced, or one of the auto parts stores and buy a flasher, then crawl under there to try and find something that looks like the new flasher.
Jul 8, 2006 at 6:52 AM
