s-10 fuel injector troubleshoot
MNORIDER
hello, I changed out the fuel injectors on my 1997 chevy s-10 , 64,000 miles,2.2l engine, and when I tried to turn it over it started but acted like it had a bad case of hiccups, then i notice the first injector didn't have a good seal and gas leaked out on to the, then it sounded like something got stuck and the motor won't turn abit , the battery is fully charged , it simply won't turn any more, i redid every thing again and got the injector to seal and put every thing back and yet it still won't turn over , the fuel pump doesound like its operating ,i'm stuck here in low di again please help , thank you kindly mno :D
Nov 3, 2007 at 3:43 AM
BLACKOP555
  • 10,386 POSTS
ok first i want to verify, when you turn the key does anything turn on? if so then its not the ignition switch. your also saying the car does not crank either? so what i want you to do is turn on the lights and try and crank it and if the lights do not dim then the starter is bad and you should check that if they do and still the engine does not crank then the starter could be jammed on the flywheel. also check for fuel pressure at the fuel rail to kn ow if the pump is good.
Nov 3, 2007 at 8:10 AM
