1998 Chevy S-10 Rear Main Seal Install
MEDICMANAZ
I have a 1998 Chevy s10 that I am replacing the rear main seal. It is a 2.2l engine. I can't seem to get the seal all the way in without fear of damaging the seal. It will not pop in like the manual says. I can't seem to find the "tool" it says is needed and a blunt tool will not push it in. Any ideas?
Sep 13, 2007 at 8:32 AM
CLY
  • 308 POSTS
I have added a picture of the installer. I have done these but can't say that I have done them without the tool. The tool is ment to hold sealing surface of the seal out while you turn the handle and it pushs the seal into place. I would make some phone calls and see if anyone would rent you or loan you the tool. That is one of those jobs that you don't want to have to go back and do it again if the seal gets damaged when you installed it....
https://images.2carpros.com/forum/automotive_pictures/86485_4320_1.jpg
Hope this helps... Cly
Sep 13, 2007 at 9:54 PM
Suggested Repair
Use the dedicated rear main seal installer, which holds the sealing lip out while the handle is turned to press the seal into place. Rent or borrow the tool rather than forcing the seal with a blunt tool, so it is not damaged and the job does not have to be redone.
Conversation Summary
The owner of a 1998 Chevrolet S-10 with a 2.2L engine cannot fully seat a new rear main seal without risking damage. It will not pop in as the manual describes, and a blunt tool will not push it in. The expert explains that the installer holds the sealing surface out while the handle drives the seal into place and recommends renting or borrowing that tool instead of risking a damaged seal.
