Chevrolet S-10 Radio No Sound
MIKE639
I have a s-10 PU its 5 yrs old and the other day when I shut the truck off I heard static in my speakers, when I turned the truck back on the radio did not work. I do get the LED readings of the preset stations and also the clock still works the only problem is no sound coming from the radio at all now.
I would appreciate any ideas you might have on what it could be, its driving me crazy! Thank you in advance, Mike
Aug 19, 2007 at 11:49 PM
  • 75,988 POSTS
[quote:7bc6f4f64a="Mike639"]I have a s-10 PU its 5 yrs old and the other day when I shut the truck off I heard static in my speakers, when I turned the truck back on the radio did not work. I do get the LED readings of the preset stations and also the clock still works the only problem is no sound coming from the radio at all now.
I would appreciate any ideas you might have on what it could be, its driving me crazy! Thank you in advance, Mike[/quote:7bc6f4f64a]
Do you have a radio theft deterrent device?
If it has a built in amp that's where the speakers gets it output from .
Also could be a fuse blown that's controlling the amp. power check all your fuses.
Aug 20, 2007 at 8:55 PM
Suggested Repair
Check whether the radio has a theft-deterrent feature, inspect the built-in amplifier that feeds the speakers, and test all fuses that supply power to the amp.
Conversation Summary
The owner of a roughly five-year-old Chevrolet S-10 pickup reported static from the speakers when shutting the truck off, then no radio sound afterward. Preset LEDs and the clock still work. The expert suggested checking for a radio theft-deterrent device, a failed built-in amplifier, and blown fuses that power the amp.
