No fuel through injector
KITTY420
  • CHEVROLET S-10
1991 Chevy S10 we have replaced the fuel pump-injector-filters-distributor-ignition control module and still have no fuel spraying from the injector this is a 2.5 the 8th letter on vin is an E and it is not 4 wheel drive but is a4 cyl.I am frustrated and fed up what can you do to help me out?Thank you for the ideas. Kitty :evil: am so fed up I think about shoving the truck off the Colorado National Monument
Saturday, March 24th, 2007 AT 6:39 PM
DUDER1
  • 15 POSTS
Check your fuse box for a fuse that has ECM1 on it, check and replace if need, other then that. It may be you oil sending unit shorting out. Just unplug it. If it starts. You'll know thats it
Tuesday, March 27th, 2007 AT 7:11 AM
