If your engine is designed for 5w30 oil then no. It usually tells you the weight requirements of the oil right on the dip stick of the oil filler cap.
If the rpm's are 1200 at idle, then twelve psi of oil is perfect! Even ten is okay at this rpm. Remember ten psi of oil pressure for every 1000 rpm's. Putting in a heavier than designed weight oil will be disastrous! Yes your oil pressure will go up however this is because there is more resistance in the system, bad. A heavier weight oil puts a lot more strain on the oil pump. It also takes more horsepower away from the engine because the oil pump must work harder to push the heavier "resistance" throughout the system. Do not believe me? Well, when a Nascar race car goes out for qualifying it usually has in it a 0w15 or (if they can get it) 0w10 weight oil. They run a scary low viscosity oil when qualifying in order to get the most horsepower. Your problem if you want to call it a problem "which I do not" may be that the bearings have too much clearance, unequal clearance, oil passages are a little clogged up or your oil pressure regulator spring is weak. High pressure is, as bad, and worse than low pressure!
Nov 29, 2007 at 1:58 PM
