2000 Chevy S-10 Jerks Into 2nd Gear
SLICK5050
2000 chevy s-10, 4.3l, 160,000kms.
When driving around 100 kms/hr for a while and then coming to a complete stop, accelerating again, the truck jumps or jerks going into 2nd gear. After that, all other gears shift smoothly but will always jerk or slip into that 2nd gear after a stop. I'll stop the truck and notice that there's some play in the driveshaft. I can move it with my hand. If I shut the truck off and go underneath again, chances are that the drive shaft will have no play and is tight again. After that, it shifts smoothly all the time. Always happens after a small highway trip. Had the universal bearings replaced and it is still happening.
Aug 20, 2007 at 9:27 PM
CLY
  • 308 POSTS
Sounds like you have a problem going on with the transmission valvebody assembly. GM has had alot of improvements and updates on there valvebody assemblies. due to alot of problems with them...
Cly
Aug 21, 2007 at 10:18 AM
Suggested Repair
Have the transmission valve body inspected and updated. GM has issued valve body improvements for harsh or slipping shifts, including the jerk into 2nd after a stop.
Conversation Summary
A 2000 Chevrolet S-10 4.3L jerks or slips into 2nd after highway driving and a complete stop, then shifts smoothly in other gears. The owner also noticed intermittent driveshaft play and replaced the U-joints without fixing the shift. The expert attributes the problem to the transmission valve body and notes GM updates for known valve body issues.
