1996 Chevy S10 Gear Shift Problem
JACODY
1996 Chevy S10 Regular Cab with 4.3 L V6 and 5 speed manual transmission. The truck has 78,000 miles and I just had the clutch, flywheel, clutch bearings and slave cylinder replaced. My question has to do with the manual gear shifter. Before it used to stay centered on 3rd and 4th gear when in neutral but after the clutch repair it just slops back and forth. I can’t seem to find a detailed schematic to see if a return spring was left off or what the problem might be. The mechanic said this was “normal” and didn’t see a problem. Any ideas on what could be causing this? Thanks for the assistance.
Nov 26, 2007 at 7:30 AM
MERLIN2021
  • 17,250 POSTS
Not having been the one who did the job, I'd say the mechanic has a few extra parts in the toolbox now! Go back and tell them to fix it right! There's no problem from here either!
Nov 26, 2007 at 7:35 AM
