2001 Chevy S10 Pickup V6 4.3L extended cab 3 door rear wheel drive 85808 miles and get my oil changed every 3000 miles and scheduled maintenance
Returned from my mechanic today and I'm pretty upset. Since I was off went to get my oil changed and a pressure check of my air system since it has never been checked or at least I never asked to have it checked. They told me that I need to replace my intake manifold gaskets because it is leaking antifreeze. Thing is they just fluhed and replaced my extended life antifreeze in Feburary and they never stated there was a leaking issue. When they initially replaced the antifreeze I did smell it. I have a credit account with them and each time you make a payment, even the minimun they give you an increase. I think I'm being taken advantage of. Please help because they want $500 which is probably more reasonable the the dealer but then in Feburary I changed the antifreeze, transmission fluid and brakes all around and 4 new tires so figured that should only have to worry about oil changes and tire rotations.. Requested to have the oil changed in Feburary because it was 3 months but not 3000 miles. Was told wait for the 3000 mile mark as if they planned to drop the big one on me when I came back. Thanks :cry: :cry:
Apr 25, 2007 at 2:44 PM
