idle problems
SUPER_SPORT_4_EVER
i have 1986 chevy s10 pick-up truck. it stays idle wide open what could cause that
Apr 27, 2006 at 4:53 AM
DABOSS
  • 5 POSTS
it could be the IAC (Idle air control valve), throttle sensor, MAP sensor, or an Air flow sensor. did u put the engine code scanner to it? if not, then do so, it should pretty much point you to the problem.
Jun 15, 2006 at 3:49 PM
SWEEP2WIN
  • 21 POSTS
What is meant by wide open? High idle speed? You noticed the air intake was open fully?
Jun 25, 2006 at 10:12 AM
