fuse box
JOHN PHINNEY
i think i blew a fuse my stereo, lighter,rear window latch, dome light all went out , i cant see the fuse box very well. but what i see i dontsee any fuses out.could it be a relay or i think i might have shorted somrthing out replacing a new stereo , where should i check?on a 91' chevy s10 blazer 4.3 litre 2 door
Apr 9, 2007 at 2:27 PM
KNIGHTRIDERKITT2000
  • 93 POSTS
pull the fuses out and look at them one by one, sometimes you cant see a blown fuse, until you pull it out of a dimly lit area.
Apr 9, 2007 at 10:44 PM
MCFERRANCE
  • 100 POSTS
You could also use a test light to see if you have power accross the fuses by grounding the test light and touching the other end on each side of the fuse. Do this with the key on to check all of them.
Apr 10, 2007 at 2:09 PM
