Fuel problem
JBS10
I have a 1993 chevy s10 pup,2WD,2.8 v6 engine,stick shift.There is about 255,000 miles on the truck.My problem is the truck consumes alot of fuel.I look at the throttle body and see that the top of it looks burnt as well as the gas coming out should be a mist but is short of a stream.I have replaced the o2 sensor,plugs+wires,distributor cap and button.I need to know where the fuel filter is so i can replace it as well any other ideas to correct this problem...Thank You
Jul 16, 2007 at 9:15 AM
MIKE H R
  • 3,094 POSTS
The fuel filter is located under the vehicle. It is on the drivers side, just about even with the front seat. It is connected to the frame . Sometime they are hard to see with the shield that covers it. Try some throttle body cleaner and injecter cleaner. should help with your low gas milage
Aug 21, 2007 at 11:12 AM
