2000 Chevrolet S-10 Fuel Gauge Inaccurate
MOPARSTONE
I have a 2000 s-10 4.3 with 11,500 miles on it. The fuel gauge reads inaccurate, always reading full, when it's not. It moves a little bit off full, but not accurate. Also, when i am at a stop light for more than a few seconds it buries the needle to E, once i tap the gas it goes back to full. thanks for the help.
Nov 9, 2007 at 1:33 PM
Good evening,
This could be the fuel sender unit in the tank, wiring or the cluster.
You will need a volt meter to test for voltage back at the tank to verify voltage to the sender.
Mar 26, 2020 at 9:29 AM
Suggested Repair
Test voltage at the tank with a voltmeter to confirm power to the fuel sender. The inaccurate gauge may be caused by the in-tank sender, wiring, or the instrument cluster.
Conversation Summary
A 2000 Chevrolet S-10 owner reports the fuel gauge stays near full and briefly drops to empty at a stop before returning when the throttle is applied. The expert says the cause may be the fuel sender, wiring, or cluster, and recommends checking voltage at the tank to the sender.
