On a 1999 s-10, auto, 4.3, how do I stop the daytime headlights from working?
Tuesday, November 27th, 2007 AT 8:38 PM
BLACKOP555
MECHANIC
First check to see if you have a fuse for daytime headlights only, if you have one that only operates tha tyou can choose to pull it.
Or you may be able to push in the dome light button 5 times fast and it should go out. Some may even need to have the ebrake put 1 click down to disable it.
