2004 Chevy s-10 4 cylinder I replaced the clutch, Pressure Plate, Throwout Bearing and turned the fly wheel lightly approximately 30,000 miles ago at 110,000 miles & it worked fine but currently it feels like it is slipping. If you are cruising @ 45 to 55 MPH & press on the gas the tach will rev up higher than normal & then settle back down. You can hear the engine over Rev. I do not feel this is a clutch problem. Can you offer any other suggestions?
SPONSORED LINKS
Tuesday, November 13th, 2007 AT 10:02 AM
