2001 Chevy S-10 Head Gasket Noise
MARY STAFFORD
have a 2001 chevy s-10 4 cylinder with 85,000 miles. had a blown head gasket due to overheating, spent $2,500 getting it repaired, cleaned heads etc. When got back first day on the road, began clanging very loudly like a valve noise, mechanic says "lots of sludge in engine and only option is to rebuild or replace engine for $3500-$4700". My question is this, would you not have pulled the pan and/or checked the oil pump before reassembly, or done an engine flush. Grew up with a father in a garage and the car belongs to a friend and I do not believe they followed good shop practice in diagnosing and repair advice, what protocol would you have followed with a blown head gasket.
Thanks
Nov 13, 2007 at 11:13 AM
BLACKOP555
  • 10,386 POSTS
i would have dropped the oil pan and cleaned it up also would have flushed hte radiator to get all the antifreeze out of the oil and all the oil out of the antifreeze.
Nov 13, 2007 at 1:35 PM
Suggested Repair
Drop the oil pan and clean out sludge, and flush the radiator and cooling system to remove antifreeze from the oil and oil from the coolant.
Conversation Summary
A 2001 Chevrolet S-10 with 85,000 miles had a blown head gasket from overheating and was repaired for about $2,500. On the first drive afterward it made a loud valve-like clanging noise, and the shop said heavy engine sludge meant a rebuild or replacement costing $3,500 to $4,700. The owner questioned whether the pan, oil pump, and an engine flush should have been checked before reassembly. The expert said the oil pan should have been dropped and cleaned, and the radiator flushed to separate antifreeze and oil.
