I'm beginning to experience where my 1997 s-10 will not start until the dash lights come on as well. I have in the past replace the ignition switch with a new one. This work was completed at a dealer and cost several hundred dollars. Tonight, I disassembled the steering column enough to remove the ignition switch and replace it myself for $16. This however did not resolve the problem. I still experience this delay in being able to start the truck. Here's basically what happens key goes in the ignition and I turn it to forward one click, the dash lights come on or I wait a few seconds and they come on. If I wait, there is no other noise I can hear. When the lights do come on, the fuel pump kicks in, the dash lights up and the car is ready to start. I can turn the key to start up and it runs fine. If I don't wait for the lights to come on and turn the key to start, it won't start. the engine will turn over but it will never start. Any ideas? I'm willing to donate to the cause the cost of the ignition switch plus some if I can resolve this problem with your help and I don't have to go to someone else for the repair. Thanks!
Jun 26, 2007 at 2:28 PM
