95 S10 Transmission problem
AJSPADE
  • 6 POSTS
I am having a problem with my transmission in my 95 S10 4wd. It shifts hard sometimes and often seems to shift up and down when just riding down the road. I know there is supposed to be a way to ajust it but I don't know how. Any ideas? Or is there something else I can try? It runs good otherwise.
Oct 29, 2007 at 3:54 PM
CHRIS1979
  • 7 POSTS
u can change your transmission fluid and filter, that may help?? also there is a lever on the side of your tranny. it will have a cable hooked on it, u can follow that cable and u should see an adjustment nut and screw. I would try the filter and oil first though ... if it has never been changed it wouldnt hurt to do so.
Oct 31, 2007 at 2:10 PM
